Old 08-07-2009, 01:13 AM   #1
LOW!!!
xBtony's Avatar
DIY:Spacing Front Fenders! Gen1
As with any DIY...If u mess it up..ITs not my fault..lol.sry..
Ok..so this is EXTERMELY useful if ur running somewhat wide wheels with an offset around 20 or lower and u are slammed, and need more clearance up front...I was rubbing real bad up front, and this got rid of like 80% of it...Only took like a half hour too...Difficulty is like..3 out of 5...maybe 2.5...Lol...
Tools that will be needed!
Tire iron or anything to take the wheels off (including wheel key if u have locks)
Flat bit and Philips head screw drivers
10mm socket!
Pick a bolt or washers to act as the spacers...Determine the size by how much room u need...Also if u go to big u will end up with a gap where the fender meets the headlight and other stuff wont fit right...
The bolt I used...
Ok..Take the wheel of!
Then take these 2 Philips screws out...Located in the wheel well
Now take the front bumper like half off to make room fer ur hand to get in ther..lol..
first..take this 10mm bolt off..located behind the grille
Then this philips screw clip thing out
Then go under the car and take out these 10mm bolts..Set the longest one aside, because u will need it for something different...The longer one is the one that goes into the metal..not the plastic clip thing
Un clip the front bumper and pull it aside to make room for u to work on, then take out the bolt that holds the fender on...
Member that bolt I told u to set aside? You'll need it now...The original bolt that holds the fender on it too short to use if ur using a big spacer like I did..so take the longer one and use it where the yellow (or w/e color ur car is) and put the painted one for the front lip
The difference
Now that the bold it out..wedge ur spacer inbetween the fender and the mount using a flat bit screw driver...
Put the screw back in...Ur fenders are spaced!
Put everything back together and ur done! HAHA! Yay!!!!!! now slam the eff out of ur car
If u have any questions feel free to PM me
xBtony is offline
Old 08-07-2009, 01:26 AM   #2
Re: DIY:Spacing Front Fenders! Gen1
you go boi tony!
you know whats coming......
SAKURA is offline
Old 08-07-2009, 01:28 AM   #3
LOW!!!
xBtony's Avatar
^hahaha! Thanks a lot Eric!
xBtony is offline
Old 08-07-2009, 04:37 AM   #4
Yeup!
Exist's Avatar
Exist is on a distinguished road
very sick, any rear mods like this =)
Exist is offline
Old 08-07-2009, 04:51 AM   #5
good diy tony. props.
ketchup_xb is offline
Old 08-07-2009, 06:53 AM   #6
Blackscionxb
blackscionxb's Avatar
blackscionxb is on a distinguished road
He'll yeah boy. .... Er.... Aahh...... Man I guess. Our little Tony is growing up in front of our very own eyes.
blackscionxb is offline
Old 08-07-2009, 01:12 PM   #7
LOW!!!
xBtony's Avatar
LMAO! Indy! Guess I am...
Thanks Heinz...
Exist..The rears are rolled and pulled..the fronts are lightly pulled as well...
xBtony is offline
Old 08-07-2009, 01:36 PM   #8
Good job on the DIY
PCH is offline
Old 08-07-2009, 01:57 PM   #9
The one and ONLY
gothbox's Avatar
a nut for spacer, LOL, LOL, phhhh
I used like a 1/2in spacer, LOL had to cut off that tab for the headlight.
nice DIY Tony.
you can also got to the hardware store and get little spacers in both metal and plastic if you do not want to go the nut road, I do not like going down the nut road, but hey thats your life choice, I do not judge.
gothbox is offline
Old 08-07-2009, 02:05 PM   #10
Balliztik
bbszero's Avatar
Nice write up Tony. I was planning on spacing mine this weekend and pulling the schitt outta my fenders to make room for when my coilovers get here next week.
bbszero is offline
Old 08-07-2009, 02:27 PM   #11
LOW!!!
xBtony's Avatar
Thanks guys! Lol @ goth..Ha!
xBtony is offline
Old 08-07-2009, 03:18 PM   #12
better keep eye on this boi, i think he'll be suprising ALOT of peeps in the years to come......little by little.
SAKURA is offline
Hatch Wiper Removal
My DIY Fuel Door mod
Grille smoothing
Blackout headlight DIY
Installing a Fab Style Wing
DIY reverse hood
Tinted Rear Markers
Page generated in 0.19985 seconds with 13 queries
