Old 06-27-2008, 04:04 AM   #1
rally xB
Rally_the_xB's Avatar
Rally_the_xB is on a distinguished road
Send a message via AIM to Rally_the_xB
DIY reverse hood
This is a DIY for a reverse hood on your Gen 1 xB
NOTICE!!!! Not responsible for ANY damage that occurs will trying to do this mod to your vehicle.
Oky doky!!!
Materials
4 foot stick of 1/4 x 1/2 x 1/2" Angle iron (Steel)
4 foot stick of 1/4 x 1/2 x 1/2" Angle iron ( Aluminum)
12, 5/16-18 X 1" soxket head cap screws
16, 5/16-18 Hex nuts
16 flat washers
4 flat washers, Nylon'
tools
Sawza, chop saw, hand saw, your gonna need somthin good to cut the steel
either a hex wrench or a hex bit on a rachet
wrenchs for the hex nuts
drill and drill bits for drilling holes
Hammer and punch
flathead screwdrivers
First, were gonna start with some simple drawings or each bracket (3 each)
1st ,bracket mounted on radiator support frame
2nd, bracket mounted on hood
3rd, hinge
NOTE!! all is mage from angle stock metal! and also keep in mind you have to make a left and right peice, so holes will be on differ sides.
Youll need to go ahead and make the brackets now.
now did you make the brackets........
well....
OK, i see you made the brackets
Lets start with mounting the brackets to the radiator support frame.
Youll need to mount it 1/2 inch down, as youll see in the pic. place the bracket on the support frame, use a pencil mark the holes to drill. now to drill the holes, youll need to remove the battery to fit the drill, and on the pass. side, the bracket on the shock tower that holds the A/C hose. Use a punch where your gonna drill the holes, makes life lot simpler. Drill your holes with the right size bit you pick if you decided on differ bolts. Once holes are drilled go ahead and mount the brackets, you may have to remove the headlights for the nuts, depends how good you are. now some pics of that bracket...
SO, you mounted the radiator support bracket. now time to add the center hinge peice, made from aluminum. your gonna use the nylon washers here. the nylon washers go between the steel and aluminum, and use washers on both sides, double nut the bolt as well. tighten them down nicly, but not super tight, you want to be able to move it, its a hinge. look at the pics above for a better idea.
same pics again
now the center peice in in place, your gonna mount the last peice to the end of the center bracket useing the same methods as above, pics for referance.
Now remove the grill with a flathead screwdriver. lower the hood, be sure not to hit the brackets! with the hood down and latched, make marks on the hood where the hood bracket meets up with the hood, kinda tight fit, but the best way i could do it.
Pop your hood, remove it, and remove the hood bracket from the center hinge part. This is where you drill the holes for the brackets. try to find a depth setter for your drill bit, you dont want it to pounch through the hood. This is a trickey area!!
everything needs to be perfect with alighment., and your gonna have to use a LARGE drill bit to drill a hole big enough to fit a nut and a finger through to put the nut on the back side of the hood.
heres a simple pic
after you get the brackets mounted on the hood, youll need a freind to help hold teh hood up to the center hinge peice using the bolts, with nylon washers between and such as said above. tighten then down good, but not to tight, again, its a pivot point and needs to be agle to move.
By this time its a reverse hood, i removed the rear hinges, but thats up to you, they dont need to be removed. close your hood, see if it lines up, HOPE TO GOD IT DOES!!! lol
heres what you end with!!!
I hopes this help, gets a little difficult in the end, but its a sweet mod!!!
Rally_the_xB is offline
Old 06-27-2008, 04:26 AM   #2
Re: DIY reverse hood
good job. i like the "vert" hood laid out.
good detail instruction.
btw, custom gauges have these kits for sale.
SAKURA is offline
Old 06-27-2008, 04:59 AM   #3
rally xB
ya, ive seen them, but you can build it yourself for cheaper, and have more pride, lol.
Old 06-27-2008, 05:45 AM   #4
no1dad1983's Avatar
pride shmide, you got balls!!! too cool bro!
no1dad1983 is offline
Old 06-27-2008, 09:49 AM   #5
boxedout is on a distinguished road
Wow...!
That's so slick, I totally dig it.
boxedout is offline
Old 06-27-2008, 12:16 PM   #6
Geriatric~Hipster
Ratty's Avatar
Location: Halfway Between The Gutter And The Stars "In the Real OC"
Ratty is on a distinguished road
Thumbs up Re: DIY reverse hood
Great Write up!
Ratty is offline
Old 06-27-2008, 12:28 PM   #7
Mother Lover...
Looks good bB! I owns you!
Padanky is offline
Old 06-27-2008, 12:35 PM   #8
rally xB
AGAIN!!!! Well, i guess robyns might have to fix that....if she can afford it, lol.
Thansk for the comments!!
Old 06-27-2008, 02:20 PM   #9
phillys phattest
Big_Jim's Avatar
Big_Jim is on a distinguished road
Send a message via AIM to Big_Jim
wow, that looks really freaken good!
thanks for the write-up!
Big_Jim is offline
Old 06-27-2008, 03:52 PM   #10
Making your own stuff rules! Very cool, man
PCH is offline
Old 06-27-2008, 04:28 PM   #11
DJ's Daddy
litos_2006's Avatar
nice DIY you got skillz
litos_2006 is offline
Old 06-27-2008, 04:30 PM   #12
now you gots to do a split hood DIY. thats what i want
ketchup_xb is offline
Old 06-27-2008, 05:02 PM   #13
rally xB
um.....hum, supply me a hood to do it with, lol, and i will do it!!
Old 06-27-2008, 05:04 PM   #14
Split hood!!!That would be a very appropriate look for the box
PCH is offline
Old 06-27-2008, 05:05 PM   #15
rally xB
well, i do want a CF hood for my box, just need to save about $700 bux to get it here, then maybe, i might do a split hood mod, i need a winter hood, the CF will be summer only till next year.
Old 06-27-2008, 05:39 PM   #16
Pippy Longstocking is hot
shortbus_8's Avatar
so choice
shortbus_8 is offline
Old 07-03-2008, 02:10 AM   #17
I got your back like C3PO
infeliciter's Avatar
that's sic. looks real nice.
infeliciter is offline
Old 07-21-2008, 09:52 PM   #18
posdriftin is on a distinguished road
thats sick reminds me of the oldschool datsun z's ....
posdriftin is offline
Old 07-28-2008, 03:39 PM   #19
raceking924 is on a distinguished road
Send a message via AIM to raceking924
sick.... coming thursday or friday
btw... +1 rep points for you
raceking924 is offline
Old 07-28-2008, 04:32 PM   #20
1tappedxb is on a distinguished road
thats sweet but I am curious as to hood vibrations towards the windshield... what latches down that part of the hood??
1tappedxb is offline
Hatch Wiper Removal
My DIY Fuel Door mod
Grille smoothing
Blackout headlight DIY
Installing a Fab Style Wing
DIY reverse hood
Tinted Rear Markers
Page generated in 0.24565 seconds with 13 queries
