Old 01-20-2007, 07:04 PM   #41
wallyh is on a distinguished road
Crazy question, how tight do you tighten the new nut on the monroe shock. Until you can't tighten anymore? Thanks for any help.
Wally
wallyh is offline
Old 01-20-2007, 07:52 PM   #42
Tomas's Avatar
Exclamation
Not a crazy question at all. I believe I got mine right (pretty damned tight), but here is the CORRECT answer (from the xB repair manual).
BTW, I did measure the length of rod from the "seat" to the end: The OEM shock and 5987 SensaTrac are identical.
(Koni - SensaTrac - OEM)
Hope that helps,
Tom
Tomas is offline
Old 01-20-2007, 08:59 PM   #43
bBsquad reppin
dancar420's Avatar
dancar420 is on a distinguished road
Hope that helps,
Tom
yeah thats why you buy the 5870 monroe's to go lower only if you have air ride
dancar420 is offline
Old 01-21-2007, 05:43 PM   #44
Thanks Tom for the quick answer and thank you surfcitylocal for the DIY article.
The install was a piece of cake and the ride does seem better.
Wally
wallyh is offline
Old 01-21-2007, 08:21 PM   #45
Wally
Always glad to help Wally.
Old 01-22-2007, 12:09 AM   #46
bigslimm's Avatar
bigslimm is on a distinguished road
Wally
Yeah good question. Like Tomas said the rods are the same length. Also the replacement top nut is the same height as the stock nut[2] (though not the same width.) Anyway, those two things being the same, an easy way to tighten to original specs in lieu of a torque wrench is to tighten until seven threads show. My stock rods each showed seven threads from the bottom nut before I removed them.
bigslimm is offline
Old 01-22-2007, 02:51 AM   #47
Straight Creepin
XBCreep's Avatar
Just curious on why you chose the shock model you did insted of the shorter 5870's. With the 5870's wouldn't the shocks "sweet spot" be more fitting to the drop you had.
XBCreep is offline
Old 01-23-2007, 10:30 AM   #48
Genesis_26317 is on a distinguished road
"yeah thats why you buy the 5870 monroe's to go lower only if you have air ride"
I missed that part of the post.
Genesis_26317 is offline
Old 06-24-2008, 01:36 PM   #49
mikel's Avatar
mikel is on a distinguished road
Re: Rear shock replacement DIY Monroe shocks
Great thread. I'm close to replacing the shocks on my 04.
mikel is offline
Old 07-06-2008, 09:48 PM   #50
no1dad1983's Avatar
i'm getting mines tomorrow! F and R
no1dad1983 is offline
Old 11-09-2008, 04:59 PM   #51
TattedXB's Avatar
TattedXB is on a distinguished road
Send a message via AIM to TattedXB Send a message via Yahoo to TattedXB
I know this is an old post, (great one btw taz) but I had a question.
I replaced my shocks with monroes about 2 years ago or so and it made a HUUUGE difference and increase the ride 10-fold. Anyways, it's about time to do it again as i've put on 50k+ miles since then. Do the same shocks (part # 5870) work on the front AND back? I plan on getting some df210's to replace my aging espelirs (spelling?) so I figure I might as well replace all 4 shocks when I put the springs on.
Thanks
Jeff
TattedXB is offline
Old 11-09-2008, 05:19 PM   #52
2bluexb's Avatar
2bluexb is on a distinguished road
i want to do this i put a box in the back and it rides like crap that box is heavy i noticed once i took it out that it rides better will this actulyl help me if i change them out?
2bluexb is offline
Old 11-09-2008, 05:25 PM   #53
Tomas's Avatar
Exclamation Re: Rear shock replacement DIY Monroe shocks
Front of xA and xB Classic are MacPherson struts rather than just shocks.
If you used standard length SensaTrac shocks in the rear (P/N 5987), they are are for a 2002-2005 Toyota Echo, and the 2002-2005 Toyota Echo SensaTrac struts (P/N 71575) will fit the front of the box, BUT it will lower the front of the box by 1/2 inch due to the spring mounts on the Echo struts being mounted 1/2 inch lower on the strut.
If the 1/2 inch drop suits you, then the 2002 Echo front struts work just fine, IF NOT, there is now a SensaTrac strut for the front of the box (P/N 72245) that is a little beefier than the Echo strut, and very similar to the stock xB front strut in performance.
If you used the P/N 5870 shocks, I'm assuming you have a lowered box, and I'm not at all sure what the appropriate strut would be for the front.
(Sadly this site is still green.)
Tomas is offline
Old 11-09-2008, 06:50 PM   #54
TattedXB's Avatar
Hey Tomas,
Thanks for the response. Well, i'll be getting some df210's in to replace my espelirs (1 1/2 inch drop I believe). I have the stock struts in the front atm, and the monroe (lowered). Perhaps i'll just leave the front alone and replace the rear again (i replaced them originally 50k+ miles ago, they're long warn out)
Oh, and the site is Green as in n00bs, or green as the background color?
Thanks.
TattedXB is offline
Old 11-09-2008, 07:13 PM   #55
Tomas's Avatar
Bilious green as in color.
Tomas is offline
Old 11-09-2008, 08:08 PM   #56
The same color as a well beaten dead horse.
Old 11-11-2008, 12:26 PM   #57
Eav10xB's Avatar
Last time I will ever ask this question again because this time I am writing it down LMAO...
i have DF210's and i need to replace the rear shocks because they suck with these springs. Should i replace the shock with the Sensa-Trac 5870s or something else for lowering and a smoother ride. Please let me know before i make a stupid mistake LMAO.
Thanks
Eav10xB is offline
Old 11-11-2008, 12:35 PM   #58
Big_Kokujin's Avatar
Trust me, you'll keep asking it until you guy them. I think i've written it down like 3 times. But I think the 5870s are what you want.
Big_Kokujin is offline
Old 11-11-2008, 12:57 PM   #59
Eav10xB's Avatar
Thank you...
Eav10xB is offline
Old 11-12-2008, 11:17 AM   #60
avinsa is on a distinguished road
hi
my question is: why does monroe recommend other shocks (2006 xb) then you install. 5601 for the back and 72245 for the front.
many thanks and kind regards
Marco
avinsa is offline
Question about Monroe shocks and struts FatalJRA Scion xB Suspension, Chassis & Brakes 1 04-25-2006 08:50 PM
Where to buy cheapest Aftermarket shocks? Dajap Scion xB Suspension, Chassis & Brakes 29 03-16-2006 07:07 PM
XB factory rear hatch spoiler thunder67 General Scion xB Discussion 14 02-21-2006 08:13 PM
Diy Hub Spacer Install
DIY: Sway Bar End Link Bushing Replacement
Page generated in 0.27429 seconds with 14 queries
