Old 01-06-2007, 10:47 PM   #21
bBsquad reppin
dancar420's Avatar
dancar420 is on a distinguished road
Originally Posted by surfcitylocal View Post
I don't have a clunk with these shocks. Did you make sure the parts were put back in the correct order? As far as the height, there was no difference with the new shocks, it's the springs that change the ride height.
I meant on the highth when you are down all the way with the air ride
dancar420 is offline
Old 01-07-2007, 03:07 AM   #22
This is where it sits right now at full drop.
Old 01-07-2007, 08:21 AM   #23
blackbox's Avatar
blackbox is on a distinguished road
so will these shocks make you sag even more when you have alot a people in the car.there are speed bumps in my housing community and i scrape the bottom of my chasee when i pass over them.i put some df210s on my car to lower it but , when i bought them they where already used, so i thought that my car was'nt gonna go any lower.well, that wasnt the case because when i first put them on it was'nt hitting like it is now.is there something wrong with my car or is this normal?
blackbox is offline
Old 01-07-2007, 09:45 AM   #24
The springs will sag with time just as a stock spring will. Shocks will wear out as well, losing their effectiveness and allowing you to bottom-out. Having extra weight in the back will also make your Box ride lower. I don't know too many peeps that have installed the DF-210's that can make it over a speed bump without going at an angle.
Old 01-07-2007, 12:41 PM   #25
bBsquad reppin
dancar420's Avatar
hey taz do you want your front to sit lower I got a way to do it . arent you using the universal air set up?
rear-shock-replacement-diy-monroe-shocks-resized_pict0447.jpg  rear-shock-replacement-diy-monroe-shocks-resized_pict0445.jpg
Old 01-08-2007, 12:36 AM   #26
You mean like this?
I flipped my upper strut mounts today and got a much lower stance. I can't drive at full drop anymore though and I have to work out something for the fender/bumper joint. I had to remove it too keep the fender from buckling.
What's your method cause it looks SEXY!
Old 01-08-2007, 12:45 AM   #27
Rubmeister
BoxerRebellion's Avatar
BoxerRebellion is on a distinguished road
^^^ man your car is looking amazing bro! The kit and stance are seriously bada$$.
BoxerRebellion is offline
Old 01-08-2007, 08:21 PM   #28
bBsquad reppin
dancar420's Avatar
hey did you flip it and leave it under the stut tower. and who did the welding on the plates for the strut bag brackets did uni air do them. cause i didnt flip them I just put them on top but if I flip them and put them on top I can probably get 2 more inches but that was with the old wheels
Old 01-09-2007, 12:17 AM   #29
I flipped the mounts but put them on top.
The welding was done by a guy at a Midas muffler shop in Brea. 20 bucks and 20 minutes on a Saturday morning.
Is that the idea you had? To flip the mounts or did you have another idea in mind?
Old 01-09-2007, 07:55 PM   #30
bBsquad reppin
dancar420's Avatar
yeah that is how I was going to tell you but its weird when I do it to mine it sits way lower. right now I just have mine sitting on top but they are not flipped and I sit just as low. do you have any pics of just the struts assembled cause that is really not safe flipped like that if you noticed the bearing is just cased in rubber and it is on top and all the weight of the car is sitting on the bearing it might just rip out. take a look at it and let me know I want to know if it looks like it is ripping
Old 01-10-2007, 01:16 AM   #31
Here's what I did to beef it up a little.
Notice the washer on top of the bearing. It keeps the pressure on the bearing housing and not just the center portion.
The interior of the strut now...
Bump stop:
Washer:
Extra bearing ( in addition to the one on top):
If you have a pic of yours post it up. I'm not clear on how you put it on top but didn't flip it.
Old 01-10-2007, 05:14 PM   #32
bBsquad reppin
dancar420's Avatar
do you have pics of the bottom bracket. I didnt use the bearing are you sure it goes inside they told me I didnt need the bearing if it had one on top. as for the top mount I just put it on top like it was on top of the strut. I guess we will have to see each other at the scinergy show at valley high.
Old 01-11-2007, 12:48 AM   #33
Well shut my mouth and call me Susan. I talked to Zack today at Universal Air. He explained the set up to me AGAIN and this time I got it right. The bearing does go on top of the upper bag plate and below the upper strut mount. I changed it over tonight and what a difference. The steering feels so much better.
Here are a few pics of the correct way.
The bottom mounting plate:
I bet Cravin (Pat) is going to be so happy when we do his install since I've done all the bonehead moves on mine. As of tonight, with the exception of a digital management system or some good gauges, the friggin' system is rockin'!
Old 01-11-2007, 07:00 AM   #34
Genesis_26317 is on a distinguished road
Originally Posted by fcastle View Post
Nice! So hows the ride? Been looking to replace the stock shocks since I put in the progressive coilovers. People say it's bouncy back there.
It's going to be bouncy back there no matter what, mine is way bouncy even with stock soft shocks.
It's not a sedan or a SUV its a stiff chasisied FWD car with a box body sitting on top of it, aka wagon. That' one of the reasons it handles so tightly, you can't have both on a car that is so reasonably priced, aka Lexus/Caddies.
What kind of springs do you have? Even with progressives it isn't going to help to much if they are race/street performance springs.
Progressives help it stay streetable while having much better performance and also help it go over bumps without flipping the car side to side and making it unstable.
I assume the xB has progressives in the front stick with linears in the rear. Anyway with hard springs and soft shocks it is going to be seriously jaring and pogo-stickish while at the same time it can be very damaging to the stock shocks (non-heavy duty) and degrade them over time well before there original lifetime expectancy is reached.
Genesis_26317 is offline
Old 01-11-2007, 01:53 PM   #35
bBsquad reppin
dancar420's Avatar
yeah now I see what is different I cut of the factory spring perch and I needed to put a pipe on and then I put the lower bracket on [the pipe was to make them fit tighter together] and I was told the lower bracket was to be no less than a 1/2 inch clearance to the tire. next time I can I will get you a picture so you know what I did. if you want when you do cravin (pat) let me know and we can hook up and I will weld his together like mine or if you want to re do yours
Old 01-11-2007, 05:28 PM   #36
rton20s is on a distinguished road
The stock shocks are anything but soft. The Monroe shocks are a much better match to our spring rate if you are seeking a smooth ride.
All reports to those with more severe drops say that using the Monroe 5870 produce a smoother ride as well.
rton20s is offline
Old 01-11-2007, 05:37 PM   #37
I'd like to see that. I have the pipe on mine it's just cut down quite a bit. I had thought about getting the Echo struts to lower the bottom spring perch but I think it would be a little too low.
Not sure if I'm understanding right, did you cut the spring perch off completely and weld the pipe to the strut? I thought about that but I didn't think it would be a good idea to heat the sucker up with the gas inside and all.
Old 01-11-2007, 05:50 PM   #38
I guess we have a different meaning of the word "soft" .
Old 01-11-2007, 05:55 PM   #39
Wow, some really nice xBs on air!
squirrel is offline
Old 01-11-2007, 08:09 PM   #40
bBsquad reppin
dancar420's Avatar
How much lower is the perch now than it was at stock height?
yeah I cut it of completely and put another pipe on and then put the bracket on and yes its welded on the strut. I didnt care cause I needed new struts
Question about Monroe shocks and struts FatalJRA Scion xB Suspension, Chassis & Brakes 1 04-25-2006 08:50 PM
Where to buy cheapest Aftermarket shocks? Dajap Scion xB Suspension, Chassis & Brakes 29 03-16-2006 07:07 PM
XB factory rear hatch spoiler thunder67 General Scion xB Discussion 14 02-21-2006 08:13 PM
Diy Hub Spacer Install
DIY: Sway Bar End Link Bushing Replacement
Page generated in 0.25185 seconds with 14 queries
