Old 05-20-2008, 07:41 PM   #1
Suspension Whore
859Toaster's Avatar
Tools needed
12mm Socket and wrench
9/16" socket and wrench
Pry bar (or Reel big screw driver)
Jack
Pack of smokes (or beer, or both)
4" long Grade 8 Bolt (Qty 2)
Energy Suspension End Link Bushings/washers
Nylon nut (Qty 2)
adjustable wrench
Time 30minutes to 1 hour (pending your skill level)
It is important to keep the suspension loaded during removal/install. If not, you will not tighten the bar to its proper location.
Work one side at a time
Remove the stabilizer bar end links bolts. There are 2 bolts. 1 top, 1 bottom. Remove the top by holding the bottom in place with a 12mm wrench. When removing the bottom bolt, use a adjustable wrench to hold the nut that is made into the stabilizer bar link. It is right bellow the rubber bushing on the stabilizer bar side.
Once you remove both nuts, remove the OEM bushings.
After bushings are removed, Use a jack to take some of the weight off the vehicle. Doing this will allow the stabilizer bar to raise up some.
Next take your pry bar and use it to pry the stabilizer bar upward on the ends. Be careful not to pry against your axle/tie rod ends. That could be damaging.
Once your factory link is removed from prying the stabilizer bar up, you want to set up your new links.
You well now take your 4" long bolt and assemble them in this order (from bottom to top, as the bolt passes threw the control arm and stabilizer bar): Bolt, Washer, Bushing (flat end facing ground), Control arm, Bushing (flat end facing hood of car), washer, washer, bushing (flat facing ground), stabilizer bar, bushing (flat facing hood), washer, nylon nut.
Should look just like this:
Next take weight off the car by lowering the jack so that the suspension re compresses. Then tighten your bolts down just enough so that the bushings slightly start to bulge out (13ft lbs of torque)
Stop, smoke (drink or both),
Catch up on any missed text messages or calls
Repeat all the steps for the other side. Enjoy the ride.
Photos from install:
Assembled off the car
Stockness:
Energy Suspension:
Stockness disassembled:
Which do you trust?
Doing this has improved my body roll. There is now less, and the car hugs threw the turns nicely. Added about 10mph to my entering speed in a few turns, safely. Of course, I am already on a tight stiff suspension. BUT it will improve your factory ride as well!
Total cost: $20
859Toaster is offline
Old 05-20-2008, 07:49 PM   #2
It's a lifestyle.
crxgames's Avatar
Re: DIY Stabilizer Bar End Links from Energy Suspensions
So uh...when we doing mine? :P
crxgames is offline
Old 05-20-2008, 07:57 PM   #3
Suspension Whore
859Toaster's Avatar
go buy the stuff and i'll be glad to get under and give ya a hand.
Old 05-21-2008, 02:00 AM   #4
bB Squad
AirecK's Avatar
i was just about to do this...nice write up!!
AirecK is offline
Old 05-21-2008, 03:51 AM   #5
mobbin
nnnickkk's Avatar
nnnickkk is on a distinguished road
Send a message via AIM to nnnickkk
i need to do it too! socal tech day? or whatttt.
nnnickkk is offline
Old 05-21-2008, 04:45 AM   #6
bB Squad
AirecK's Avatar
shouldn't take too long...
AirecK is offline
Old 05-21-2008, 03:12 PM   #7
I <3 my bB
mr_bb2u's Avatar
mr_bb2u is on a distinguished road
Send a message via AIM to mr_bb2u Send a message via MSN to mr_bb2u Send a message via Yahoo to mr_bb2u
where did u get these from? i need to install my hotckis front sway bar so i can purchase this also and kill two birds with one stone.
mr_bb2u is offline
Old 05-21-2008, 06:14 PM   #8
Suspension Whore
859Toaster's Avatar
Does the hotckis bar not come with new front end bushings? I would think/hope it would. But if not, its worth it.
If your bar comes with links, i'd use those (unless they look weak like stock)
Old 05-21-2008, 11:22 PM   #9
I <3 my bB
mr_bb2u's Avatar
this is all the hotckis front sway bar comes with....that piece u did goes on the end of the sway bar am i correct?
mr_bb2u is offline
Old 05-22-2008, 08:05 AM   #10
Suspension Whore
859Toaster's Avatar
yes it does. I'm surprised the bar doesn't come with new links
Old 05-22-2008, 09:25 AM   #11
I <3 my bB
mr_bb2u's Avatar
im not complaining i got both front and rear sway bars for $100 shipped off ebay. thanx for the info im going to check out autozone today or tomm..
mr_bb2u is offline
Old 05-22-2008, 12:03 PM   #12
Suspension Whore
859Toaster's Avatar
damn man that's a nice score on ebay.
If your autozone doesn't have them, you can get them on summits web site
Old 05-29-2008, 10:34 AM   #13
TRD Whore
kev1NZFE's Avatar
kev1NZFE is on a distinguished road
Nice writeup! I did this mod yesterday and the drive to work today felt a whole lot better. You can really feel a difference on entrance and exit ramps; I can pretty much go 10 mph faster on them.
kev1NZFE is offline
Old 05-29-2008, 10:38 AM   #14
Hella Bastos
niiice. i need to do this fer sure. awesome write up. thumbs up.
ketchup_xb is online now
Old 05-29-2008, 10:47 AM   #15
There is already a DIY on this one but nice job.
Old 05-29-2008, 12:24 PM   #16
Suspension Whore
859Toaster's Avatar
so I heard. However I did not see one in the DIY forum so I felt the need to do one here. This way its easy to find for those who are against using the search button. LOL
Old 05-29-2008, 01:26 PM   #17
Stark Industries
hotweelz4me's Avatar
Nice upgrade. I'm looking to do this with Super Pro products
hotweelz4me is offline
Old 05-29-2008, 11:47 PM   #18
comeon socal peeps, let get a group buy from NEXT LEVEL MOTORING and have a tech day!
btw, nice pics!
SAKURA is offline
Old 05-30-2008, 01:44 AM   #19
G2k
G2k is on a distinguished road
I did this a few months ago. Bang for buck this is a great mod. It actually took me longer than posted but I always take longer. As I remember you really gotta thread the needle to get all that new stuff back on while trying to tighten it.
Just a heads up. If your are not confident to do this you might consider getting some help.
G2k is offline
Old 05-30-2008, 02:48 AM   #20
agentorunge is on a distinguished road
Send a message via AIM to agentorunge
Did this mod today also, just a little difficult cuz there isnt much room working under there when you wanna retighten since you gotta lower the car some, but still got it done. awesome mod, those who haven't done this should get on it!
agentorunge is offline
Diy Hub Spacer Install
Page generated in 0.29491 seconds with 13 queries
