Old 06-25-2006, 02:48 AM   #1
ThunderGod's Avatar
Camber Bolts up front
w/o camber bolts
w/ camber bolts
you can get these Camber bolts from NLMOTORING
Replace both strut to spindle mounting bolts to achieve up to ±2°.
You know the procedure. safety first, use proper tools, perform this at your own risk. you are liable for your own modding.
Camber bolts
Set parking brake on, jack it up, use proper blocks/jack stand, remove wheels.
Using 19mm socket/wrench, lossen the top bolt only. remove the bottom bolt completely.
Insert camber bolts per instruction. (make sure you read it! you need to install it properly) use 15mm for the bolt, and you will need 18mm for the locknut.
Tighten everything up to spec. manually, and visually check everything. test drive vehicle safely.
ThunderGod is offline
How To Take Of The Front Shocks Bolts??? TCM_bb69 Scion xB Suspension, Chassis & Brakes 11 06-06-2006 02:59 PM
how to install??? iheartmyxb Scion xB Suspension, Chassis & Brakes 26 03-23-2006 03:36 AM
Front Bags failed today.............. krazylowgsx Scion xB Suspension, Chassis & Brakes 9 03-09-2006 08:29 PM
More Camber and new mounts for air ride! Dajap Scion xB Suspension, Chassis & Brakes 49 02-12-2006 03:37 PM
Front sway bar questions Ghost_1 Scion xB Suspension, Chassis & Brakes 11 01-10-2006 08:45 PM
Diy Hub Spacer Install
Page generated in 0.18213 seconds with 14 queries
