Old 02-22-2007, 09:20 AM   #1
That Guy
ShortBus's Avatar
Short Ram Intake DIY
Tool List:
Flat Head Screwdriver
Phillips Head Screwdriver
Ratchet with 10mm and 1mm deep sockets and a 12 inch extension
1) Remove the four 10 mm bolts securing the engine cover and the engine cover.
2) Unplug mass air flow sensor
3) Unplug harness from vacuum switching solenoid and vacuum hoses. (06 model earlier models will differ)
4) Remove crankcase breather hose from intake tube and valve cover
5) Loosen clamp securing intake tube to throttle body.
ShortBus is offline
Old 02-22-2007, 09:27 AM   #2
w00st3r's Avatar
Thank you Sir. when i get my intake i will certainly use this for reference.
w00st3r is offline
Old 02-22-2007, 09:29 AM   #3
That Guy
ShortBus's Avatar
6) Unclip air box top.
7) Remove the upper portion of the air box.
8) Remove air filter element and compare with what is being installed (fun)
9) (more 06 differences) remove the vss from the air box
10) Install the vss won the included bracket (may need different screw)
11) Remove 10mm bolt securing the air duct.
ShortBus is offline
Old 02-22-2007, 09:43 AM   #4
That Guy
ShortBus's Avatar
12) Remove three 10mm bolts securing lower portion of air box.
13) Remove lower portion of air duct box from vehicle.
14) Disconnect and remove the battery. Starting with the negative terminal.
15) Install the bracket with the vss with the factory bolt and washer.
16) Install the short straight hose (2.25") with clamps to the throttle body (tighten only the throttle body side)
17) Install the filter onto the intake
18) Remove the mass flow air sensor from the factory air box
19) Install the mass flow air sensor on to the intake (note different screws may be needed)
20) Slide intake into fender well (this is a bit of a fit, but be careful of wires)
ShortBus is offline
Old 02-22-2007, 09:53 AM   #5
That Guy
ShortBus's Avatar
21) Install the vibration mount on to the battery tray.
22) Install intake into the straight hose and onto the vibration mount.
23) Tighten the remaining clamp on the intake side of the straight hose.
24) Secure the vibration mount with the washer and nut
25) Plug the mass flow air sensor up
26) Reinstall the batter and secure it with the tie down.
27) Install the 15.9mm vacuum hose onto the crankcase breather and intake pipe and secure it with the factory clamps.
28) Do a second check to make sure anything that was moved is plugged in. Especially watch the vss and maf!
29) Install the engine cover to complete the install.
Finally have fun
ShortBus is offline
Old 02-22-2007, 03:51 PM   #6
www.evolved-concepts.com
2005scionbb's Avatar
2005scionbb is on a distinguished road
Send a message via AIM to 2005scionbb
do you feel any gains????
2005scionbb is offline
Old 02-22-2007, 04:09 PM   #7
Dita_and_Dahlia is on a distinguished road
I'm curious too if you have any gains...and do you have an automatic or a manual trans?
Dita_and_Dahlia is offline
Old 02-22-2007, 04:26 PM   #8
That Guy
ShortBus's Avatar
It is an automatic. I don't get into the throttle too much, but my wife says she can feel some gains and says that it doesn't take near as much throttle to accelerate.
She did say that she burned some rubber today without even trying.
ShortBus is offline
Old 02-22-2007, 04:28 PM   #9
That Guy
ShortBus's Avatar
After reading through it there is one typo. The other socket is supposed to be 12 mm not 1 mm.
ShortBus is offline
Old 02-22-2007, 05:58 PM   #10
BLACKTOPXB is on a distinguished road
does the filter touch your foglight and make it vibrate like my aem cai does?
BLACKTOPXB is offline
Old 02-22-2007, 10:28 PM   #11
That Guy
ShortBus's Avatar
Don't have any fog lights. Sorry. I think this one seems to be high enough not to get in the way.
ShortBus is offline
Old 02-22-2007, 11:54 PM   #12
what about you gaas mileage?? did it improve it?? juss curious.
Old 02-23-2007, 09:07 AM   #13
That Guy
ShortBus's Avatar
Dont know yet. Just got it installed and it cleared the trip when I unhooked the battery. I will let you know later this week though.
ShortBus is offline
Old 02-25-2007, 11:25 AM   #14
spyder720 is on a distinguished road
Thanks for the post. I'm getting my Fujita SRI so this poat will help alot.
spyder720 is offline
Old 03-05-2007, 11:12 PM   #15
theboxboy's Avatar
theboxboy is on a distinguished road
Send a message via AIM to theboxboy Send a message via Yahoo to theboxboy
thanks i installed my intake today, they helped!!! now my box is one step closer to being the best box around east texas, all i need now is my rims (comming soon) the body kit (on order) and a pain job (dont know when im getting that.... then i shall cont. to make it my own... muhahhaa
theboxboy is offline
Old 03-06-2007, 03:24 AM   #16
i gotta know where ya got it man can ya tell me??? wait before anybody tells me use the dam search button. i am directing this question for shortbus. maybe he got it from a local shop or something where it can be picked up. hey ya gotta help the little guy survive somehow.lol..
Old 03-06-2007, 09:00 AM   #17
That Guy
ShortBus's Avatar
Its an ebay item. Just be patient and you can get it for around $120 shipped. It really is a good sounding and quality part. I have been very pleased thus far.
ShortBus is offline
Old 04-07-2007, 03:05 PM   #18
ayS
ayS's Avatar
ayS is on a distinguished road
Send a message via AIM to ayS
Re: Short Ram Intake DIY
great write up! alot easier then i thought. the write up looks alot harder then it truly is.
ayS is offline
Old 04-22-2007, 08:10 PM   #19
Al Choholic
toybox777's Avatar
helpfull, did my injen cai in record time , don't work on your box on the street next to a drain, thats a good way to lose a socket
toybox777 is offline
Old 04-22-2007, 10:13 PM   #20
Skeeter's Avatar
The ydr is the same as the fujita but cheaper, you can damn sure hear the sucking of air with the short ram. And the ydr comes with a K&N filter as well.
Ebay, $69 with free shipping
Skeeter is offline
F5 Fujita short ram intake squirrel Scion xB Engine, Tech, & Performance 38 09-23-2009 10:55 PM
Question for you short ram intake guys gargamel Scion xB Engine, Tech, & Performance 15 01-04-2008 07:16 PM
Short Ram Intake/Cold Air Intake x2theB Scion xB Engine, Tech, & Performance 34 04-21-2007 02:26 PM
Short Ram Intake: which is the best? btangonan Scion xB Engine, Tech, & Performance 34 04-16-2007 05:18 PM
YDR Short Ram Intake (debadged - used) FS superjeer Scion xB Classifieds 5 05-08-2006 11:55 PM
DIY: Changing your own oil
DIY: Spark plug replacement
Page generated in 0.28914 seconds with 15 queries
