Old 07-06-2006, 04:05 PM   #1
sid
otoh ko toh neh
sid's Avatar
The "REQUIRED MAINTENANCE" light comes on every 5,000 miles to remind you to change your oil. Press the odometer button and turn the key to the on postion and wait for the odometer reading to count down and stop blinking. This will reset the required maintenance light
sid is offline
Old 07-07-2006, 02:36 PM   #2
Element Owner
AAronInTheBox's Avatar
AAronInTheBox is on a distinguished road
this is how it worked for me:
key is in "on" position
hold odometer button
turn key to "acc" position
then back to "on" position
wait for the countdown on the odometer
thanks SID!
AAronInTheBox is offline
Old 07-23-2006, 11:04 AM   #3
Xbox63's Avatar
Xbox63 is on a distinguished road
right on for this fix.
Xbox63 is offline
Old 08-06-2006, 11:40 PM   #4
tomato23 is on a distinguished road
i try to work as u said, but it just didn't work.........
tomato23 is offline
Old 08-20-2006, 12:34 AM   #5
Skeeter's Avatar
Make sure the odometer in on odometer and not on the trip meter. Key off, push and hold the trip reset in, turn key on and bamp it will count down, 5, 4, 3, 2, 1, 0 and wala good for antother 5K miles or is it 3K miles?
Skeeter is offline
Old 08-20-2006, 02:54 AM   #6
06b0x's Avatar
06b0x is on a distinguished road
Send a message via ICQ to 06b0x Send a message via AIM to 06b0x Send a message via MSN to 06b0x Send a message via Yahoo to 06b0x
It's 5k!
06b0x is offline
Old 08-30-2006, 07:02 PM   #7
thx, fix it right away
tomato23 is offline
Old 09-08-2006, 12:13 AM   #8
BonBon is on a distinguished road
Warning Lights wont shut off
Have made many trips to my Toyota Scion Dealer with warning lights shown as VSC Track On and the emblem of an engine
1st trip they thought it was the gas cap
2nd trip their senson equipment not working
3rd trip they tell me I need a charcoal cylinder replace and it has to be ordered
4th trip they install it
48 hrs later the lights are back on. They do more checking and tell me it is part of the gas cap neck that leads to the outside? Anyway, the part has been ordered. I have just a little over 5,000 miles, car will be 1 year old on Sept. 30. I LOVE MY SCION, but this is getting frustrating. Anyone have a similiar problem. Thanks.
BonBon is offline
Old 10-26-2006, 08:43 AM   #9
theboxboy's Avatar
theboxboy is on a distinguished road
Send a message via AIM to theboxboy Send a message via Yahoo to theboxboy
well...i have let one of my firends. drive mine..it is a stick shift.. when igot into my box the track light was on , the transmition check light was on , the vcs light and a few others .. it was freaking nutz but other than that .. i have never heard of such weird things with the import.. good luck
theboxboy is offline
Old 10-30-2006, 08:48 PM   #10
dadmann is on a distinguished road
Thanks a ton guys... saved me some bucks on this one. I appreciate it.
dadmann is offline
Old 11-24-2006, 10:58 AM   #11
xBot is on a distinguished road
"Have made many trips to my Toyota Scion Dealer with warning lights shown as VSC Track On and the emblem of an engine
48 hrs later the lights are back on. They do more checking and tell me it is part of the gas cap neck that leads to the outside? Anyway, the part has been ordered. I have just a little over 5,000 miles, car will be 1 year old on Sept. 30. I LOVE MY SCION, but this is getting frustrating. Anyone have a similiar problem. Thanks."
Low Tire pressure will also cause this problem
xBot is offline
Old 12-08-2006, 02:13 AM   #12
spyder720 is on a distinguished road
Thanks for the tip
Reset the light and had no problems. Thanks for the tip.
spyder720 is offline
Old 05-21-2007, 05:47 PM   #13
Mavrichie's Avatar
Mavrichie is on a distinguished road
Send a message via Yahoo to Mavrichie
Re: re-setting the "Required Maintenance" light
Thanks for the tip man it worked perfect.
Mavrichie is offline
Old 06-09-2007, 06:15 PM   #14
carguy70001 is on a distinguished road
Thanks for the tip, it worked great. I used the #1 post as the pattern.
carguy70001 is offline
Interior light. OMAC Scion xB Lighting & Electrical 26 08-14-2007 08:18 PM
Light in door speaker well..... KapitanE Scion xB Lighting & Electrical 5 05-29-2006 01:07 PM
New Mod - Light in Cargo area KapitanE Scion xB Lighting & Electrical 8 05-22-2006 08:50 PM
Fog Fog Fog Light Light Light scionbox123 Scion xB Lighting & Electrical 6 05-15-2006 07:13 PM
Dome light cover caden_stargate Scion xB Lighting & Electrical 4 05-08-2006 09:39 AM
DIY: Changing your own oil
Short Ram Intake DIY
DIY: Spark plug replacement
Page generated in 0.23664 seconds with 14 queries
