Old 01-14-2007, 02:24 AM   #1
scvscions's Avatar
After you buy an Optima battery for your Scion, the positive cable doesn't reach anymore so here's the DIY to fix that problem:
MATERIALS NEEDED:
1"x2" strip of aluminum 1/8"thick (this can be found at a hardware store)
(1) 8mm x 1.25 x 20mm bolt
(1) 8mm x 1.25 nut
(2) 8mm or 5/16 flat washers
(1) 8mm or 5/16 lock washer
Red locktite
tape measure
metal saw/die grinder/snips
drill with 5/16 bit or Unibit (my favorite)
marker
Let's begin now:
First I measured out the piece of aluminum to mark.
I made a 2" line for cutting. (I never said I could do a straight line)
It should look like this now.
Now it's time for the marks for the holes. I measured 1/2" from the out side edge on each side and put a dot dead center in the aluminum. (hint: the aluminum has lines running thru it so that you can know that you have it on the correct mark. In this picture they run horizontal.)
Drill a 5/16 hole at each mark. You can check this with your bolt to see if you are done. Using the unibit will give you a better look.
Here's after the holes are drilled.
I cleaned up the edges a little on a grinder and sander but that's your preference.
Here's the finished product installed:
If anyone doesn't want to make them but wants one I'll do it for $10 to cover the cost of materials and shipping. I do this as a hobby. Thank you and I hope it helps.
Jason
scvscions is offline
Old 01-14-2007, 11:30 PM   #2
Nice. Guess there's nothing to stop me from getting the Optima now....
Besides the extra cash!
Old 01-15-2007, 12:13 AM   #3
Very nice work Jason. This is gonna help a lotta peeps.
Old 01-15-2007, 11:43 PM   #4
EvoluScion's Avatar
EvoluScion is on a distinguished road
I dont know why I did mine the way I did. I should of done it your way. I made my stock one fit somehow without any extension... maybe its because I have a blue optima?
Peace
EvoluScion is offline
Old 01-16-2007, 01:53 AM   #5
scvscions's Avatar
Just trying to help. I get bored a lot at work...who wants to do what their supposed to anyway.
Old 01-16-2007, 11:28 AM   #6
EvoluScion's Avatar
Lol, I think your mod is a good one. Someone else told me that there might be kits that do just that and extend the battery terminal but I never found one that fit. So your mod is helpful, the only prob is to mod a plastic cover so it still covers, and mine barely covers the terminal correctly.
Peace
Old 01-16-2007, 10:30 PM   #7
greenguyshrek's Avatar
greenguyshrek is on a distinguished road
Send a message via AIM to greenguyshrek Send a message via Yahoo to greenguyshrek
Nice write up.
greenguyshrek is offline
Old 01-17-2007, 11:41 AM   #8
boxeryo's Avatar
boxeryo is on a distinguished road
i am not sure what this batt does for the xb can you explain why is it better then the one that is already on there
boxeryo is offline
Old 01-17-2007, 01:24 PM   #9
Mother Lover...
Now just have them anodized to finish the look, nice work.
Padanky is offline
Old 01-17-2007, 07:42 PM   #10
The yellow top is if you have a big audio setup. I think the Red and blue top are just replacements.
Old 01-19-2007, 09:21 PM   #11
mplayboy72's Avatar
mplayboy72 is on a distinguished road
Ill buy one of those if you still got one, I pm'ed you
mplayboy72 is offline
Old 01-26-2007, 03:48 AM   #12
scvscions's Avatar
I'm selling them for $10 shipped if anyone else wants one.
Old 01-29-2007, 06:19 PM   #13
06BoomBox's Avatar
06BoomBox is on a distinguished road
Send a message via AIM to 06BoomBox Send a message via MSN to 06BoomBox Send a message via Yahoo to 06BoomBox
the blue top is for marine purposes, its the best one for the job if you have alot of electrical devices that require a lot of power, its a deep cycle battery, im getting ready to get one for mine once im running my 2 2000 watt amps and 4 5000 watt kicker subs...
06BoomBox is offline
Old 02-22-2007, 04:16 PM   #14
rampagesd is on a distinguished road
Send a message via AIM to rampagesd
here's the break down for optima batteries
red top - dry cel non-deep cycle battery (just like a regular battery but you can mount it in any posisition)
yellow top - dry cel deep cycle battery (good for cars w/ upgraded electronics)
blue top - marine dry cel deep cycle battery (best all around)
only bad note bout these bout these batteries is that they die quick if your car isn't a daily driver. then again if your car isn't a daily driver you should unplug your battery anyway.
rampagesd is offline
Old 04-16-2007, 10:20 PM   #15
L4rry_B1rd's Avatar
L4rry_B1rd is on a distinguished road
Re: Optima Battery Extention Bracket DIY
Are these still available?
And can anyone tell me what size Optima I should buy for the xB?
L4rry_B1rd is offline
Old 04-16-2007, 10:35 PM   #16
yes they are still available you can get them at almost every automotive store like pepboys or autozone. you'll be fine w/ the regular size one they make.
Old 04-17-2007, 01:09 AM   #17
scvscions's Avatar
The optima battery # is sc34a and PM me about the bracket
Old 04-17-2007, 01:53 AM   #18
ThunderGod's Avatar
brackets are awesome!
ThunderGod is offline
Old 04-17-2007, 01:10 PM   #19
DJ's Daddy
litos_2006's Avatar
just like TG said the brackets are awesome I got one awhile back easy to install
litos_2006 is offline
Old 04-17-2007, 03:50 PM   #20
smokeydadog is on a distinguished road
My stereo's nothing great--50x4 head unit and 325w amp with 1 10" sub--but soon I'll be hooking up an Xbox in my car. This will be running off a 400w inverter and going to my in-dash DVD player. When I go camping I might also plug in a 13" TV. Obviously the stock battery will take a beating from this. Which Optima would be the best for my setup?
smokeydadog is offline
Optima Yellowtop Misterflipper Scion xB Engine, Tech, & Performance 22 04-16-2007 10:38 PM
AEM Rubber Mount Bracket MrF Scion xB Engine, Tech, & Performance 17 01-12-2007 05:30 AM
JDM Plate Bracket *REAL* solara2xb Scion xB Classifieds 0 12-05-2006 04:11 PM
Optima Batteries solara2xb Scion xB Lighting & Electrical 12 11-20-2006 11:35 AM
wtb License Plate Bracket azynboi03 Wanted Scion xB Parts and Vehicle 11 03-23-2006 10:42 PM
DIY: Changing your own oil
Short Ram Intake DIY
DIY: Spark plug replacement
Page generated in 0.26940 seconds with 14 queries
