Old 10-16-2009, 11:11 PM   #1
babelbox's Avatar
babelbox is on a distinguished road
DIY: Automatic Transmission Drain and Refill Oil
I just did a quick 'drain & refill'. My xB is at 72127 miles, auto trans. According to the Service Guide, there's no need to replace the ATF under normal driving conditions. It also says in the ATF dispstick. But I was curious to see what it look like after all this mileage. I'm planning to send a sample ATF to Blackstone Labs (not affiliated) for analysis. It costs about $20 to have it analyzed. I'll post the report when I get it back.
Tools I used
10mm Hex Wrench
Empty 5qt Oil jug (container)
Paper towels
Funnel whit a the spout small enough to fit the ATF Dip Stick hole
Parts :
ATF Type T-IV - $4.83 at the dealership
Drain Plug Gasket (Washer) - $1.50 at the dealership (picture of the used one)
1. Locate the Transmission Drain Plug, right underneat the auto trans oil pan. It is at the opposite side of the Engine Oil drain plug.
2. Removed the drain plug with the Hex wrench. Removed the gasket as well.
3. Let the ATF drained into the empty 5qt. jug. It helps to use a funnel into the jug to catch all the ATF Fluid. When it was done, it drained close to 3 qts. According to the service manual, the ATF Drain & Refill called for 3.1 US qt.
4. Installed a new gasket and the drain plug. According to Service Manual, the drain plug torque is 36 ft. lbs.
5. Remove ATF dispstick. This one had a reddish colored handle. And place the funnel.
6. I first poured 2.5 qts. Started the car. Let the engine warmed up to running temperature (about 180 degrees in mine) and moved the shift lever from P to L then back to P again.
7. Wiped the ATF dip stick clean and inserted it back to the pipe. Took it out and checked if the level is at the hot position.
8. Left the car running and poured some more ATF fluid until it reached the right level.
9. Put back the ATF dispstick, inspect for leaks underneat then cleaned up. Will dispose the old ATF at my town's Recycling depot.
Here's a comparison of the old and new ATF.
Note : According to the Service Manual, the ATF Dry fill called for 7.2 US qt. If I understand this correctly, I only replaced about 44% of the ATF Fluid. I guess I have to drain and refill it again soon.
babelbox is offline
Old 10-17-2009, 09:54 AM   #2
CBSIMONSEZ's Avatar
CBSIMONSEZ is on a distinguished road
Send a message via AIM to CBSIMONSEZ
Re: DIY: Automatic Transmission Drain and Refill Oil
i wonder ....
If anyone makes a synthetic tranny fluid &
If it would be worth it to replace the filter ( if there is one ) while you have the lower end empty?
CBSIMONSEZ is offline
Old 10-17-2009, 01:32 PM   #3
05blackbox is on a distinguished road
Send a message via AIM to 05blackbox
the best way to service the transmission is to have a transmission flush service done to it it will replace all the fluid that is in the transmission and in the torque converter or if you dont want to go through that you can replace the filter.
05blackbox is offline
Old 10-17-2009, 07:03 PM   #4
Stark Industries
hotweelz4me's Avatar
Originally Posted by CBSIMONSEZ View Post
i wonder ....
There are synthetic options out there for example B&M Trick Shift Synthetic ATF. Replacing the filter would also require a new pan gasket. A ATF flush and full replacement of synthetic fluid would be a nice upgrade down the road.
hotweelz4me is offline
Old 10-17-2009, 08:19 PM   #5
BG Makes synthetic trans fluid: BG Products, Inc.
Nice DIY
PCH is offline
Old 10-17-2009, 10:00 PM   #6
i forgot about bg we used them all the time when i worked at the dealership but they do have awesome stuff if you call around im pretty sure you could find a shop that uses there products and they will use the synthetic fluid for the tranny when they do the flush
Old 10-17-2009, 10:45 PM   #7
silvertoast's Avatar
i wonder ....
royal purple max atf is compatable doesnt say on the bottle but if u go to the website it is compatable with what the service manual says to use.
im currently running it in mine
silvertoast is offline
Old 10-17-2009, 10:54 PM   #8
06xbox's Avatar
06xbox is on a distinguished road
I work at a Toyota dealership and we recommend every 15k to change the Type T-4 fluid. I know Toyota says there is no need to change the fluid but I wouldn't recommend that at all. At 15k I have seen it totally black like the picture above. Def. a great write up!
06xbox is offline
Old 10-18-2009, 10:49 PM   #9
falcondrgn is on a distinguished road
What is toyota's definition of "Normal Driving"? Does stop and go traffic in NYC qualify as normal driving or severe driving? If what you are saying is accurate you mean we should change our transmission oil every 15,000 miles? That sounds awfully soon.
falcondrgn is offline
Old 10-19-2009, 12:55 PM   #10
06xbox's Avatar
That would qualify for severe driving. Toyota and other auto manufacturers are very vauge when describing the maintenance schedules. Actually if you live in a climate where it is hot in summer and cold in winter this qualifies for the "severe" plan. I have seen it completely black at 15k or even sooner. Do what you feel is the best but I was always taught its better to do maintenance more often than not enough it will never hurt your vehicle.
06xbox is offline
Old 10-19-2009, 01:44 PM   #11
The one and ONLY
gothbox's Avatar
i use Royal Purple in gothbox, I dropped the pan and changed the filter and gasket as well when I did that. Picked both the filter and gasket up at Auto Zone as a "combo kit" for not a whole lot of $$.
gothbox is offline
Old 10-19-2009, 01:53 PM   #12
VIP Member
enuf2spare35's Avatar
I used Redline in the Toy Bx
enuf2spare35 is online now
Old 10-19-2009, 05:36 PM   #13
CBSIMONSEZ's Avatar
Good to know guys. Looks like ill be waiting until the spring when the weather warms up a little to change the tranny fluid.
Old 11-03-2009, 08:57 PM   #14
babelbox's Avatar
Here's the result of the ATF Analysis. Total miles on ATF was 72,127. 2004 Scion xB, Auto Trans. This is my daily driver, 77% highway / 23% city.
babelbox is offline
Old 11-03-2009, 09:20 PM   #15
dubeexb06 is on a distinguished road
Well, have to say that you have opened a new can of worms. Your results look to be good. Thanks for showing the results.
dubeexb06 is offline
Old 11-03-2009, 10:21 PM   #16
20k before we get to see the next results.....
btw, good stuff.
SAKURA is offline
Old 11-04-2009, 12:49 AM   #17
Nor-Cal Balliztik
Eav10xB's Avatar
I need to do this before it starts raining im at 50k miles and need this done asap!
Eav10xB is offline
DIY: Changing your own oil
Short Ram Intake DIY
DIY: Spark plug replacement
Page generated in 0.28156 seconds with 13 queries
