my airbag light is on, and scaring the crap outta me ! - Scion xB Forum
 1Likes
post #1 of 94 Old 11-10-2009, 09:06 AM Thread Starter
hectik's Avatar
Quoted: 1 Post(s)
hectik is on a distinguished road
Send a message via AIM to hectik Send a message via Yahoo to hectik
Hey does anyone know of any problems with the airbag's? i already put it on my diagnostic reader and got no codes, checked the fuse panel and dont see a fuse for the srs...i dont know how to check the sensor, but if it was the sensor it should of pulled up a code...any idea's, anyone?
hectik is offline
post #2 of 94 Old 11-10-2009, 09:29 AM
Black_Sheep_xB's Avatar
Quoted: 0 Post(s)
Re: my airbag light is on, and scaring the crap outta me !
A standard scanner will not find the code. Could be the clock spring in the steering wheel, a seat belt sensor, or an impact sensor (possibly the SRS computer).. No way to tell, unless you just worked on something, had an electrical issue or get an SRS/ABS code scanner to look at it.. then we can start narrowing things down. For now, reset the ECU and see if it comes right back.. or what happens.
I have seen a dead battery and a loose connection under the seat trigger a code on newer Hondas.. never had an issue with the B.
P.S.
If it scaring you because you might think something is going to "POP" on you.. if the light is on, the system is shut down
Last edited by Black_Sheep_xB; 11-10-2009 at 09:29 AM. Reason: Automerged Doublepost
Black_Sheep_xB is offline
post #3 of 94 Old 11-10-2009, 11:14 AM
Quoted: 3 Post(s)
^^^ Good info.
To show SRS codes it needs a shop scanner with enhanced OBD2 software.
PCH is offline
post #4 of 94 Old 11-10-2009, 11:26 AM
Quoted: 0 Post(s)
^^ Like that Snap-On Solus
wait.. maybe it just does ABS.. can't remember
Last edited by Black_Sheep_xB; 11-10-2009 at 11:26 AM. Reason: Automerged Doublepost
post #5 of 94 Old 11-10-2009, 11:29 AM
Quoted: 3 Post(s)
I wish it was mine
It does Chassis (VSC/ABS/Trac) and Body (SRS). For a few $K.
PCH is offline
post #6 of 94 Old 11-10-2009, 11:32 AM
Quoted: 0 Post(s)
I had one in 2005 .. older model. but still the god of scanners.. The Ethos does SRS.
*Sorry to mini thread jack
lol -
*Edit:
Well there you go.. that thing is awesome
Last edited by Black_Sheep_xB; 11-10-2009 at 11:32 AM. Reason: Automerged Doublepost
post #7 of 94 Old 11-10-2009, 11:57 AM
Quoted: 3 Post(s)
Hectic, tell me the production month of your 05, i may be able to tell you how to read the codes without the scanner.
PCH is offline
post #8 of 94 Old 11-10-2009, 12:44 PM
clubxb = the awesomeness
endyouXB's Avatar
Quoted: 0 Post(s)
endyouXB is on a distinguished road
hectik I had a ford taurus sho that used to do that... and I can totally relate to being worried about getting popped in the face with one of those death bags... but according to the very intelligent people above me, there shouldn't be anything to worry about IF the light is on... have you googled other xB owners experiencing this issue?
slow moving vehicles need to stay in the OTHER lane!
endyouXB is offline
post #9 of 94 Old 11-10-2009, 12:45 PM
rushbuster70's Avatar
Quoted: 3 Post(s)
rushbuster70 is on a distinguished road
Mines on all the time but my dash is wrapped
rushbuster70 is offline
post #10 of 94 Old 11-10-2009, 12:51 PM
endyouXB's Avatar
Quoted: 0 Post(s)
have you ever had yours looked at? perhaps you have an idea on the cause for the problem?
endyouXB is offline
post #11 of 94 Old 11-10-2009, 01:11 PM
Quoted: 3 Post(s)
The following info is for 05 models July to Dec production:
To read present SRS codes turn the ignition ON and wait 1 minute. On the underdash OBD2 connector jump terminals #4 and #13 (paper clip is fine).
The SRS light will start blinking a two digit code (may be more than one). Count flashes separated by pauses.
For example **_*** is a Code 23.
If you have more than one code, like 23 and 41 it will look like this:
**_***____****_* then it will pause for few seconds and repeat.
DickInABox likes this.
PCH is offline
post #12 of 94 Old 11-10-2009, 01:20 PM Thread Starter
hectik's Avatar
Quoted: 1 Post(s)
thanx pch, ill try that in a bit! thanx to everyone with such quick responses....oh by the way it happened when i went to the carwash the other day and got my oil change done...also i been kinda having a problem with my alternator/battery,it was giving a problem outta no where and now it seems to be just fine..things are getting wierd as i close in on the 100,000 mile mark !
hectik is offline
post #13 of 94 Old 11-10-2009, 02:05 PM
Quoted: 0 Post(s)
low voltage for a period of time will trigger an SRS code.. but try to pull a code using PCH's method. GL.
post #14 of 94 Old 11-10-2009, 02:46 PM
Quoted: 3 Post(s)
lol i was joking.Mines ok because there is no airbag on the passenger side.Pulled it out!
post #15 of 94 Old 11-10-2009, 03:05 PM
xBtony's Avatar
Quoted: 0 Post(s)
xBtony will become famous soon enough xBtony will become famous soon enough
Mines been on ferever..lol. well since i threw the aftermarket wheel on. i gotta grab my sharpie
"Riding low aint low if you can ride high"
No. 5 Top Poster Royalty
vv My Blog vv
WTF FACEPALM
^^ Read It ^^
xBtony is offline
post #16 of 94 Old 11-18-2009, 10:26 AM Thread Starter
hectik's Avatar
Quoted: 1 Post(s)
thanx for the advice on how to read to codes pch, but i got a 26 and haven't the slightest on what that means cause i cant find anything online with srs codes...do you by any chance know what this is?
hectik is offline
post #17 of 94 Old 11-18-2009, 10:31 AM
Quoted: 3 Post(s)
Code 26 is "Seat Belt Buckle Switch RH Circuit Malfunction"
PCH is offline
post #18 of 94 Old 11-18-2009, 10:36 AM Thread Starter
hectik's Avatar
Quoted: 1 Post(s)
but wouldn't the seltbelt light be on also? if not how should i go about fixing this?
hectik is offline
post #19 of 94 Old 11-18-2009, 10:42 AM
Quoted: 3 Post(s)
You can check if any of the wires ging to passenger belt buckle are broken or disconnected. If you have a multimeter check the resistance by disconnecting the switch under the seat. With belt clicked in should read 1K-1.5KOhm ad with belt off 100-500 Ohm. Do all checks with disconnected battery.
PCH is offline
post #20 of 94 Old 11-18-2009, 10:53 AM Thread Starter
hectik's Avatar
Quoted: 1 Post(s)
Dude you rock..so i checked the wires connected to the bottom of the seat b4 and the were still connected, but what i forgot to check was the harness on the side next to the center console! Thanks so much for assisting me through this ! I go nuts when there a light on in my car !
hectik is offline
